leveling kit?
leveling kit?
What is a leveling kit do? raise the front end? Nothing to the rear? different from lift I would guess the lift kit raises the front and back?
Thanks,
Thanks,
The Teraflex leveling kit has 2 one inch spacers (per side) for the front and 1 one inch spacer (per side) for the rear (as well as extended sway bar links). You can add any or all based on the height adjustments desired.
I added all of them to compensate for a 3/4" drop from the weight of a winch and to get a little more height.
Just got my kit today and was going to install it tomorrow but instead of the 1 3/4" front and rear they sent 1 3/4" for the front and 3/4" for the rear. Do you think that would level it on a 2011 2 door or should I wait and get what I ordered ? Just seems like the 2 door doesn't have as much rake as the 4 door. Don't want the fornt to look higher than the rear. Any help would be appreciated.
