Lets Solve the Stock Springs Question
Old 10-16-2013, 04:02 AM
  #721
kaptkrappy's Avatar
Originally Posted by Green-man
So I'm having a hard time figuring all this out... I have a 2011 2dr sport with 14/56 coils and the teraflex levelling kit, 2 inch front 1 inch rear spacers and longer front swaybar links. I also have a heavier front bumper and winch. If I install rubi 4dr coils which are 17/58 would I have any issues? I have the rubi shocks as well.
Also I'm guessing on the front coil numbers they have no tags.
Sounds like a perfect setup. Should'nt cause any issues. Definitely put those Rubi Red shocks on.
Old 10-16-2013, 04:18 AM
  #722
Green-man's Avatar
Sounds like a perfect setup. Should'nt cause any issues. Definitely put those Rubi Red shocks on. .
So I shouldn't have to worry about extending my rear swaybar links and brake line mounts?
Old 10-30-2013, 08:49 AM
  #723
LoneWolf's Avatar
2009 X two-door
Soft top
Both front springs are 13s
Rear springs are 55s
F
According to my build sheet, I have the trailer tow group and the performance suspension package, FWIW.
Old 11-06-2013, 04:17 AM
  #724
onebuilder's Avatar
Originally Posted by MikeK46
Here you go! Swapped out the OEM Sahara shocks and springs (13/55's) for Rubicon shocks and taller springs (18/59's).
We also added 1" TeraFlex coil spacers all around, installed JKS Quick Disconnects up front, and swapped out the front & rear Lower Control Arm & Track bar hardware for Synergy's Grade-9 hardware kit.
Before
After
Next to stock Rubicon
Gained 2.5" up front and 2.0" in the rear
Thanks for posting your pics! Good looking Jeep!
How do you like the conversion? I'm considering doing the swap.
Old 11-18-2013, 04:03 AM
  #725
BadBry's Avatar
1 - Rubicon 2 door
2 - Hard top
3 - 52126314AC
4 - 68004257AA
5 - Your Shock Part Number only if Red/Rubicon shocks: 186AC Front & 188AC Rear
6 - The fourth Digit in your VIN: H (No Kidding!)
7 - 2014
How many other vins now have an "H" as a fourth Digit?
Old 11-18-2013, 06:44 PM
  #726
lateralus's Avatar
I had 14/55's on my 2012 2 door sport. I replaced with 18/59's and got 1-7/8 in the front and 1-3/8 in the rear of extra height.
Old 11-19-2013, 11:50 AM
  #727
jadmt's Avatar
Originally Posted by BadBry
1 - Rubicon 2 door
2 - Hard top
3 - 52126314AC
4 - 68004257AA
7 - 2014
my 2013 and 2014 have B as the 4th digit. probably a 2 door vs 4 door thing
1. Rubicon 4 door.
2. hard top
3. 18AC
4. 60AA
5.
6. B
7. 2014
Old 12-06-2013, 11:13 AM
  #728
jasonl's Avatar
Same exact set up as mine stock 14/55's and I just ordered JKU 18/59 take offs. I was hoping for 1-3/4 to 2" front and rear. I have a set of 3/4" daystar spacers front and rear now that I can use to fine tune. Can anyone tell me if I will need brake relocation brackets or longer sway bar links? I am gonna replace the stock Rubi 32" tires with some 285/70-17 33's when my BFG KM's wear out in about a year or so. Love the picks of the black Sahara, that is exactly what I'm looking for as mine is a daily driver. Thanks !
Old 12-07-2013, 04:24 AM
  #729
kaptkrappy's Avatar
I have 18/59's and a 3/4" coil spacer in the front only. I also have 1.5" SpiderTrax wheel spacers.
285/70/17 Cooper AT3's
The brake lines are fine, any higher and I would make some brake line lowering brackets.
The front swaybar links are a little short, the rear links are OK.
I am shopping for some front quick disco links for the front (you here that Santa).
Name:	Work 12-3-2013 med.jpg
Name:	Up Close Pass med.jpg
Old 12-07-2013, 09:05 AM
  #730
jtphoto JK's Avatar
With that much lift you should also be looking at rear Trackbar relocation bracket and either longer shocks or shock extensions, bumpstop extensions and proper swaybar links. Especially if you intend on wheeling it.
In essence what you have achieved with the spring swap and spacers is a very poor and incomplete 2-2.5" lift. In the end you would have been as well off just to buy a complete 2.5" lift with all the proper parts. Now you will be paying more to buy the parts separately.
The objective of the factory spring swap is not to gain more height but rather to maintain factory height when adding heavy bumpers, winch and armor.
Quick Reply: Lets Solve the Stock Springs Question
