Lets Solve the Stock Springs Question
Old 02-19-2012, 08:42 PM
  #541
Tonka_yellow's Avatar
Originally Posted by JK Q8
thanx guys! some previous posts mentioned that the 19/60 springs will improve the ride especially with the rubi shocks that I just got and I wanna maintain a
close ride quality to stock.
I hope that I can get at least 3/4" up front if I switch from 17/58 to 19/60, because my wheels have a 4.75 backspacing.
I'll install the new tires after swapping shocks and springs, and if there is any rubbing it would probably be against the air dam so I'll trim it!
The ride will only improve if you at the shocks.. and as far as the dealer knowing about the springs, just take the tags off them.
Old 02-20-2012, 04:37 AM
  #542
MikekiM's Avatar
I found a dramatic and discernible improvement in ride quality, most obvious in the reduction of dive, squat and yaw. There are a few spots on my ride to work where the truck would predictably go un-balanced through a turn or over bumps and the Rubi gear improved the rigs stability by a decent margin. Makes me wonder how much better a top-line suspension could be.
And duh... I didn't think about removing the tags... Can we have a do-over on my last response?
Old 02-20-2012, 09:43 AM
  #543
granth77's Avatar
Are the red shocks the same for both 2 dr and 4 dr?
Old 02-21-2012, 03:58 AM
  #544
atomthompson's Avatar
Yes they are. Everything is the same except the springs.
Old 02-22-2012, 02:13 PM
  #545
JK Q8's Avatar
I got the Rubicon shocks, and i want to make sure of installation, the front's model number ends with 86 AC and back ends with 88 AA ? is this correct or there is no difference ?
Old 02-22-2012, 02:21 PM
  #546
From what I remember that sounds correct.
Old 02-22-2012, 04:03 PM
  #547
KDBinAZ's Avatar
The mounting studs are totally different from front to rear do there is no way you can mistakenly mount the rears in the front or vise versa
Old 02-22-2012, 07:46 PM
  #548
JK Q8's Avatar
Thanks alot for the help guys!
Old 03-07-2012, 11:50 AM
  #549
granth77's Avatar
My JK is getting a set of 19's installed today. I already had 59's from the factory. I'll post my results when I get home.
Old 03-07-2012, 06:00 PM
  #550
granth77's Avatar
19's were installed today. Here are the numbers, before and after.
2008 Unlimited Sahara
Dual tops, tow pkg.
Stock was 15/16 in front, 59's in the rear.
Front stock height (from ground to bottom of flare, straight up from the wheel center) = 34.5"
Front height after the 19's installed (same measuring point) = 35 5/8"
So, just over an inch gain in front. Again, I didn't change the rears. It looks good, but I may opt for a TF leveling kit in the future to really level everything out.
Grant
Quick Reply: Lets Solve the Stock Springs Question
