Lets Solve the Stock Springs Question
Old 01-25-2012, 06:14 AM
  #521
MikekiM's Avatar
Originally Posted by KYJEEP
Why did my Rubi jku
Soft top
Tow package
Have 17/59's?
This doesn't seem to be the nom
I am going to take a guess on this..
When I bought my 2011 it was born with a soft top, but I wanted a Freedom top, so the dealer pulled the hard top off a another 2011 on the lot... I ended up with 14/55's on a new JK with a soft top.. Maybe.. your JK was the donor of a hard top to another JK ?
Old 01-25-2012, 07:41 AM
  #522
hypeiv's Avatar
1 - Unlimited Sport S
2 - Hardtop only
3 - 16/17
4 - 59
5 - black
6 - B
7 - 2012
Doesn't seem like I would get much of a boost with 18/19 and 60's so I guess I have to decide between a leveling kit with springs or a 2.5 lift.
Old 01-25-2012, 08:58 AM
  #523
suicideking's Avatar
Why did my Rubi jku
Soft top
Tow package
Have 17/59's?
Probably because you got the tow package. This is the same setup I ended up with on my JKU Sport with tow package, though I have the hard top.
Old 01-25-2012, 09:05 AM
  #524
MikekiM's Avatar
2 - Hardtop only
3 - 16/17
4 - 59
5 - black
6 - B
7 - 2012
I think it was determined that we stand to gain about 1/3" per spring rate increase.
Old 01-25-2012, 08:00 PM
  #525
hypeiv's Avatar
Originally Posted by drexelpike
Depends on your tire goal really. JKU w hard top and those springa can fit 35"s with just a leveling kit
Interesting... I was thinking about going with the leveling kit that had the springs instead of the spacers.... I guess I could try to source some 19's and then get the spacer kit... that might be a little cheaper
Old 01-26-2012, 12:47 PM
  #526
atomthompson's Avatar
With the springs you are starting with I'd just do a budget boost. That small of a change wouldn't really be worth it. There are tons of ways to fit 35's on a jk with little cost. A budget boost with shock extensions seems like one of the best bangs for the buck. Or no lift and chopped fenders. A jku can also be lifted higher (except 2012's) without driveline mods. Or get a spring lift kit like the Old Man Emu HD kit and then sell your factory springs to offset some of the cost.
Old 02-13-2012, 10:12 AM
  #527
granth77's Avatar
Those of you that have bought new springs, where did you go? I've been price shopping several places online and the best I've found is $33 for the 19 spring and $40 for the 18 spring. Any place better than that before I pull the trigger?
Also, I'm looking at pn's 52126318AC and 19AC. But, I've also seen 18AB and 19AB, as well as 18AA and 19AA. Whats the difference?
Old 02-15-2012, 05:17 PM
  #528
Grimmjpr's Avatar
Ok I'm adding some info here maybe this will help someone.
I was running 14s in the front and from the ground to the curved part of the flare i was at 39 inches both sides with a low tank of fuel.
I added a RR XHD winch bumper with ends/hoop, and a Warn 9.5 cti-s. Springs sagged to about 38 1/8 passenger and 38 1/2 driver with about 3/4 tank of fuel. Not bad didn't ride bad but the extra rake was bugging me and i figure the extra weight was being hard on the springs so i ordered up some 16 springs.
After install and bouncing the suspension a bit to get everything set, i measured 39 1/4 passenger and 39 3/8 driver with the same about 3/4 tank of fuel......
My goal was to keep the height as close to stock as i could. i figure after the springs settle a bit it should be just where i wanted it.
Just some info for everyone......HTH
Old 02-17-2012, 04:55 PM
  #529
granth77's Avatar
Getting ready to order my front springs tomorrow. The Jeep currently has a 15 on the drivers side and a 16 on the pass side. Should I order an 18 and 19, or just two 19's?
Old 02-18-2012, 03:36 AM
  #530
DirtyDi's Avatar
Go with the two 19's. I wondered that too and I'm pretty happy with the setup, even after 15k miles...
Quick Reply: Lets Solve the Stock Springs Question
