Lets Solve the Stock Springs Question
#521
When I bought my 2011 it was born with a soft top, but I wanted a Freedom top, so the dealer pulled the hard top off a another 2011 on the lot... I ended up with 14/55's on a new JK with a soft top.. Maybe.. your JK was the donor of a hard top to another JK ?
#522
1 - Unlimited Sport S
2 - Hardtop only
3 - 16/17
4 - 59
5 - black
6 - B
7 - 2012
Doesn't seem like I would get much of a boost with 18/19 and 60's so I guess I have to decide between a leveling kit with springs or a 2.5 lift.
2 - Hardtop only
3 - 16/17
4 - 59
5 - black
6 - B
7 - 2012
#523
#524
I think it was determined that we stand to gain about 1/3" per spring rate increase.
#525
Interesting... I was thinking about going with the leveling kit that had the springs instead of the spacers.... I guess I could try to source some 19's and then get the spacer kit... that might be a little cheaper
#526
With the springs you are starting with I'd just do a budget boost. That small of a change wouldn't really be worth it. There are tons of ways to fit 35's on a jk with little cost. A budget boost with shock extensions seems like one of the best bangs for the buck. Or no lift and chopped fenders. A jku can also be lifted higher (except 2012's) without driveline mods. Or get a spring lift kit like the Old Man Emu HD kit and then sell your factory springs to offset some of the cost.
#527
Those of you that have bought new springs, where did you go? I've been price shopping several places online and the best I've found is $33 for the 19 spring and $40 for the 18 spring. Any place better than that before I pull the trigger?
Also, I'm looking at pn's 52126318AC and 19AC. But, I've also seen 18AB and 19AB, as well as 18AA and 19AA. Whats the difference?
#528
Ok I'm adding some info here maybe this will help someone.
I was running 14s in the front and from the ground to the curved part of the flare i was at 39 inches both sides with a low tank of fuel.
I added a RR XHD winch bumper with ends/hoop, and a Warn 9.5 cti-s. Springs sagged to about 38 1/8 passenger and 38 1/2 driver with about 3/4 tank of fuel. Not bad didn't ride bad but the extra rake was bugging me and i figure the extra weight was being hard on the springs so i ordered up some 16 springs.
After install and bouncing the suspension a bit to get everything set, i measured 39 1/4 passenger and 39 3/8 driver with the same about 3/4 tank of fuel......
My goal was to keep the height as close to stock as i could. i figure after the springs settle a bit it should be just where i wanted it.
Just some info for everyone......HTH
#529
Getting ready to order my front springs tomorrow. The Jeep currently has a 15 on the drivers side and a 16 on the pass side. Should I order an 18 and 19, or just two 19's?
#530
