Lets Solve the Stock Springs Question
Old 04-01-2011, 11:58 AM
  #221
Phantasm's Avatar
Originally Posted by tls001
1 - Unlimited X with A/T and tow package
2 - Soft Top
3 - Your Front Left Spring Number: 52126317AC
P/S: 52126318AC
4 - Your Rear Spring Number: 68004459AA
5 - Your Shock Part Number: Black
6 - The fourth Digit in your VIN: G
7 - 2009
Ditto except my rear is only a 58AA as I have a Soft Top (I bought a hard top at the time of sale but my springs were not changed accordingly.)
Old 04-01-2011, 02:47 PM
  #222
Battlefrog's Avatar
Originally Posted by KDBinAZ
X2 on the two people helps above, does help to one push down on the opposing side.
I've done coil swaps on two jeeps now (one being mine which included swapping shocks as well) and have not had any issues with alignment or recentering steering wheel.
Forum member explained to me yesterday that with a BB or any lift (I believe) your axle will now be off centered by 1/8"-1/4" and as you go "bigger" it gets worse, I.E. Adjustable track bar. Hope this helps...
Old 04-01-2011, 03:01 PM
  #223
KDBinAZ's Avatar
Does make sense as the axles did move around a lot, any idea (measurements) how to check? Drives fine and does not drift, even when hitting the brakes hard. I did check my toe and that appears fine
Old 04-01-2011, 04:52 PM
  #224
Battlefrog's Avatar
Don't quote me, but measure how far each tire sticks out from fender. Measure from center of axle to outer edge of tire. I was looking for the thread I was on yesterday but could not locate it.
Old 04-01-2011, 07:03 PM
  #225
KDBinAZ's Avatar
Thanks, will take some measurements tomorrow and see how I sit. Much appreciated
  #226
Battlefrog's Avatar
Indeed...
Old 04-01-2011, 07:44 PM
  #227
DirtyDi's Avatar
Originally Posted by philg4d
DirtyDi, How much lift did you get?
I didn't get to measure it as I needed to head to the coast but I'll measure Sunday when I get home. Just by looks alone, somewhere between 1 1/4 to 2". But I also put bumpers and a winch on.
Old 04-11-2011, 07:00 PM
  #228
arasco85's Avatar
im wondering if it worth trying to find and install 19's in the front. i currently have 17's. after my bumper and winch the front is a sagging. what you guys think? i know i can go buy a lift...but im still under warranty and would like to keep it that way.
Old 04-11-2011, 07:52 PM
  #229
awesomo's Avatar
Default 2011 JKU hardtop
The fourth position of my vin is a 'B'....what is my GVW?
Old 04-11-2011, 08:16 PM
  #230
awesomo's Avatar
Default Spring part number
How do you determine the part number of your springs?
Quick Reply: Lets Solve the Stock Springs Question
