Lets Solve the Stock Springs Question
#201
#203
Originally Posted by mmcc
Hi Daggo66... Are you running them on a 11 JKU Rubicon- were they stock on the purchase or an after purchase - hows the ride - does your JK sit level with these?
#204
Cool... I'm picking up a set on Monday from my local dealer 19/60's - sounds like from the feedback they will help with the extra weight I've added with bumpers and roof rack... Will report back on outcome after I install with measurements before and after!
#205
thanks
#207
160.00 w/tax... I had a 10 percent coupon I used - I thought it was a pretty good deal.
How did you do on the used set?
Any questions on the install let me know, pretty easy mod
#208
p.s. you still in AZ? I lived in Tempe for a few years back in early 2000.
#209
Thanks bud... a few questions: where's the best place to start from - do you remove one wheel at a time or both working from an axle with body jacks - what about brake lines... loosen them from the bracket I would suspect would be a good idea... Any first hand advice would be appreachiated?
Disconnect shocks, Sway bars and brake line brackets (support axle with stock jack)
Lower axle until springs can be removed.
Same process for the front. Did both ends with stock jack and jack stands
Yes in queen creek, moved here from WI two yrs ago, love it!
#210
Rear-Remove both wheels, jack up both sides and supported with stands by the frame in front of the wheel.
