Left front brake is dragging after new pads
Yesterday I put new front brake pads on the rig. Drove to the store and smelled brakes burning and smoke coming from left front wheel. There is no leaking from the break lines. Went home bleed all four brake lines, brake fluid was a little dark to. greased the slides where the pads set, checked the metal clips for damage, no signs. Piston pushes out when brakes are applied when caliper is off the rotors. both mounting bolts float freely. Reinstalled caliper and bolted it down. When I applied the brake peddle and then released it while the front end was jacked up I could not spin the front left wheel freely. put the tire back on and could rotate the tire a little easier but it wasn't moving a freely as the right front tire. I think the left front caliper might be bad or the brake line. Any other Ideas? Input is appreciated!
