JKU Rubicon Not Starting
Old 09-06-2024, 09:50 AM
fry24's Avatar
Default JKU Rubicon Not Starting
Hey everyone, long time lurker here. I’m lost on my Wrangler. Long story short, wife was driving and out of no where lost all power, tried starting again but it just kept cranking. I towed it home and thought I knew the answer, I was suspecting the fuel pump was going bad. After a whole day of dropping the tank and replacing the fuel pump, all I’m getting is cranking still. I tried the whole TIPM fuel pump bypass, no luck. Have not checked spark yet, going to check it tonight, but we just had the entire engine replaced only about 6 months ago so I didn’t think to check it. Any thoughts? I know fuel is getting to the engine, I pulled a line off and cranked and fuel is spraying, but the jeep continues to only crank to no avail.
2011 JKU Rubicon, 150k miles, only after market parts are lift, tires, bumpers.
edit: no codes are popping either
Old 09-08-2024, 07:40 AM
Jay2013jk's Avatar
Update on the findings about Spark..
Old 09-08-2024, 01:06 PM
fry24's Avatar
Sorry got held up by other projects. No spark, tried throwing on a new ignition coil, still no luck.
Old 09-08-2024, 03:07 PM
Jay2013jk's Avatar
It worked for 6 months.. I'd check for Gounds being loose , pinched wiring, connectors .. and maybe crank sensor
Old 09-08-2024, 03:21 PM
fry24's Avatar
M19 Fuse. Somehow I had over looked this in the beginning when trying to diagnose. At least I have a new fuel pump and a new ignition coil now
Quick Reply: JKU Rubicon Not Starting
