Jk wont start
Jk wont start
08 JK sport won't start. It sounds like it wants to and then it cuts off. Pulled the white fuse can't remember what number it is and it started and now it won't start again. The resister light comes on when I try to start it battery is good. I checked that. Possibly a neutral safety switch?
You can try shifting to neutral and if it starts its your neutral safety switch. By the it starting and then shutting off it sounds like it might be something else.
Your N/S can easily be bypassed, but first see if this TSB applies to you:
TSB - No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM / SKREEM
March 04th, 2008 | Category: Electrical TSB, Jeep JK TSB & Recalls
NUMBER: 08-007-08
GROUP: Electrical
DATE: March 04, 2008
SUBJECT:
OVERVIEW:
This bulletin involves the replacement of the Wireless Control Module (WCM). The WCM is
also referred to as the Sentry Key Remote Entry Module (SKREEM).
MODELS:
2007 - 2008 (JK) Wrangler
NOTE: This bulletin applies to vehicles built on or before November 30, 2007 (MDH 1130XX).
SYMPTOM/CONDITION:
The customer may experience a no engine crank and/or a no engine start condition. Also, the remote keyless entry (RKE) system may not operate. This condition may be due to an electrostatic discharge (ESD) from the ignition key into the Wireless Control Module (WCM), causing the WCM to electronically lockup. This condition may occur more
frequently in dry and/or cold weather conditions where a sufficient electrostatic charge is more easily produced. This condition is corrected by the replacement of the WCM.
Until the WCM is replaced, the WCM may be reset (unlocked) by either: disconnecting and then reconnect the battery negative cable at the battery, or by removing the IOD fuse (with the key out of the ignition switch), waiting 30 seconds, and reinstall the IOD fuse.
TSB 08-007-08
NUMBER: 08-007-08
GROUP: Electrical
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
TSB 08-007-08
We use to make an external TRS that got it out of the hot transmission fluid but we discontinued it.
I can post a TRS bypass we use for our expidition customers that can't have a failure in the middle of nowhere.
Below is a picture of what I did to bypass the TRS if I should get the click-no-start issue.
A gentle pull on the floss will close the starter relay contacts and force the starter to turn over no matter what is going on with any of the safety cutout features, even if the key is out of the ignition switch.
The engine will start only if the key is in the switch, and in the RUN/START position.
I tested it under the following conditions.
1. Key out, transmission in PARK: engine turned over; engine did not start.
2. Key in RUN/START position, transmission in DRIVE: engine turned over; engine started.
I've never had the click-no-start issue, so I can only assume this bypass will result in an engine start should it happen to my JK. This isn't a permanent fix for the issue, but it should get me going if it happens at an inopportune time.
Last edited by ronjenx; 06-18-2015 at 03:33 PM. Reason: Memory ain't what it used to be!
The engine will start only if the key is in the switch, and in the RUN position.
2. Key in RUN position, transmission in PARK: engine turned over; engine started.
3. Key in RUN position, transmission in DRIVE: engine turned over; engine started.
