Jk Lube & Capacity Info
just some good knowledge
2007 JEEP WRANGLER 3.8L 6-cyl Engine Code 1
FILTERS
Oil Filter......... EAO57 AMSOIL Ea Oil Filter
Oil Filter......... SDF57 Super Duty Full-Flow Engine Oil Filt ...
Oil Filter......... 51348 WIX 51348 Oil Filter
TRICO WIPER BLADES
Blade Class Driver Passenger Rear
EXACTFIT T151 T151
EXACTFIT T151 T151
EXACTFIT T151 T151
EXACTFIT T151 T151
WINTER T37150 T37150
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
All Temps......5W-20, 5W-30[1]
Manual Transmission,.....GLS[2]
AMSOIL Synthetic Synchromesh Transmission Fluid
Automatic Transmission.....AP4
Synthetic Automatic Transmission Fluid
Standard Differential, Front 186 FBI.....GL-5[3]
All Temps......80W-90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Standard Differential, Front 216 FBI.....GL-5[4][5]
Severe Gear 75W-90
Standard Differential, Rear 198 RBI.....GL-5[6]
Severe Gear 75W-90
Controlled Slip Differential, Rear 198 RBI.....GL-5*[7][8]
Severe Gear 75W-90
Standard Differential, Rear 226 RBI.....GL-5
Severe Gear 75W-90
Controlled Slip Differential, Rear 226 RBI.....GL-5*[9][10]
Severe Gear 75W-90
Standard Differential, Rear W/ Towing package.....GL-5[11]
All Temps......75W-140
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Transfer Case,NV241.....AP4
Fluids
Power Steering Fluid.....AP4
Brake Fluid.....HB
1. SAE 5W-20 or SAE 5W-30. Check oil fill cap for proper engine
oil viscosity usage.
2. GLS is a special gear lube, Mopar part no. 04874464.
3. All W/ Trailer Tow PKG use synthetic GL-5 oil SAE 75W-140.
Mopar part no. 04874469. Trak-Lok axles require Mopar
limited slip additive 04318060.
4. CS IDENTIFICATION: Metal tag atached to rear cover
stamped W/ "Use Limited-Slip DIFF Lube only".
5. All W/ Trailer Tow PKG use synthetic GL-5 oil SAE 75W-140.
6. Synthetic based oil.
7. CS IDENTIFICATION: Metal tag atached to rear cover
8. All W/ Trailer Tow PKG use synthetic GL-5 oil SAE 75W-140.
9. CS IDENTIFICATION: Metal tag atached to rear cover
10. All W/ Trailer Tow PKG use synthetic GL-5 oil SAE 75W-140.
11. Synthetic based oil.
CHASSIS LUBRICATION
Four-wheel drive
5-20 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Two-wheel drive
7-8 Fittings, 0 Plugs..........LM
CAPACITIES
Engine, with filter..........6.0 quarts
Cooling System, Initial Fill..........13.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, Initial Fill..........4.0 quarts[1]
Automatic Transmission, Total Fill
4 speed 42RLE..........8.8 quarts
Manual Transmission, NSG370..........3.2 pints
Differential, with 186 FBI Front..........2.1 pints
Differential, with 216 FBI Front..........2.7 pints
Differential, with 198 RBI Rear..........3.9 pints
Differential, with 226 RBI Rear..........4.7 pints
Transfer Case,NV241..........4.2 pints
1. With ENG at operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
TORQUES
Oil Drain Plug.....20 ft-lbs
Transfer case
Fill Plug.....15-25 ft-lbs
Drain Plug.....15-25 ft-lbs
Manual Transmission
Fill Plug.....22 ft-lbs
Drain Plug.....22 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)
OTHER TOP QUALITY PRODUCTS
Mothers® Car Care Appearance Products
By-Pass Oil Filters
FILTERS
TRICO WIPER BLADES
EXACTFIT T151 T151
EXACTFIT T151 T151
EXACTFIT T151 T151
EXACTFIT T151 T151
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Severe Gear 75W-90
Severe Gear 75W-90
Severe Gear 75W-90
Severe Gear 75W-90
Severe Gear 75W-90
Severe Gear 75W-90
Severe Gear 75W-140
Fluids
Brake Fluid.....HB
CHASSIS LUBRICATION
Four-wheel drive
Two-wheel drive
CAPACITIES
as needed.
TORQUES
Transfer case
Manual Transmission
SERVICE INTERVAL
By-Pass Oil Filters
