Jeep won't start, antitheft engaged?
First post, used the search for years, thanks, 2013 JK with manual transmission. Disconnected the battery to install a new clock spring and headlight. Hooked everything back up and it started and died about three times. Now it won't even turn over. Headlights work, winch, etc. battery seems strong, it started right up 3 times. Now you can turn the key and all the lights come on as normal but it won't turn over and the engine light is flashing. Could some sort of antitheft have been triggered? Is there a reset? Tried the battery disconnect for 30 minutes and tried pulling the IOD fuse for 30 as well, am totally stumped
I had a similar problem and it was a dead WIN module. This is the module that checks the chip in the key and then allows the start if it matches. I also have a 2013 JK.
I took it to the dealership, they said it was the skreem module, cost is 378, glad it was in my barn and not somewhere on the road,
it would be nice to have a standalone controller for the pentastar
Just for future reference, there is an unlabeled red light next to the fuel gauge. That red light turns on if the antitheft system doesn't like your key. Reset by disconnecting and reconnecting battery. If that doesn't repair, as someone else mentioned, the WIN module could be the problem. Officially, this system is called the Security Key Immobilizer System. I expect that the WIN module and the part that the dealer changed for you are one and the same.
Codes u0141 u0168 and u0146. Maybe some others. Next morning the light was off and it has not come back on since. So Idk!!!
