Jeep Won't Start
Old 06-28-2012, 04:43 PM
Dexter Morgan's Avatar
I've had the same issue on my 08 for about a year now. Battery is new and usually I wait a few mins up to half hour, then it starts. I figured it was the starter but will check ground wire and plugs.
Old 06-28-2012, 10:40 PM
IBJEEPN's Avatar
"No crank" has been an issue with my 08 Rubicon once before and it has happened again. Starter replaced, ground strap replaced and transmission range sensor replaced. Taking it to originating dealer in Jasper ga.next Tuesday TO HAVE TRANS PAN PULLED AND VALVE BODY TAKEN OUT TO GET TO THE SWITCH. iT'S COVERED UNDER LIFETIME POWER TRAIN WARRANTY.
Old 06-29-2012, 04:49 PM
Novae21's Avatar
Let me know if that works, did you buy the life time warranty or is that on all jeeps?
Old 07-04-2012, 02:11 PM
Novae21's Avatar
Well I put a grounding wire from my batt to the alternator and so far so good , wish me luck!
Old 07-05-2012, 05:37 PM
Ruger48's Avatar
Default Also having same problem
Replaced started with new OEM $173.00....Did myself
Will try the ground wire fix tomorrow.....
Had battery and Alternator tested by dealer ...all OK
Hope this works...Ruger48
Old 07-05-2012, 11:02 PM
IBJEEPN's Avatar
Novae21, I bought my 08 just when they instituted the Lifetime Power Train Warranty, so I did not purchase anything additional. In fact, will get the 5 year inspection done when they replace the range sensor switch. I've got 67,000 on it. Been a good Jeep, change oil and rotate and balance tires every 5,000, change front and rear axles every 20,000, transfer case done @ 40,000, transmission done @ 55,000 and plugs/wires/pcv valve replaced @ 60,000. Maintenance is the key.
Old 07-06-2012, 06:16 PM
Mopahls's Avatar
Default good ground
Check to make sure your ground is good.
Old 07-06-2012, 07:00 PM
magnum306's Avatar
Originally Posted by Dynamo
Hey,
Pardon my automotive ignorance. My Jeep engine died tonight, and I can't get it going again.
Check out this video of the engine as I try and start 'er up:
Jeep Engine Trouble - YouTube
Any ideas? Starting motor? Battery?
The electrical system is cutting out, lights flickering etc. It's a 2008 2dr auto.
Help would be appreciated.
Here's what the dash is telling me:
http://img826.imageshack.us/img826/9889/imagetnfr.jpg
Sounds like you need a new battery!
Old 07-15-2012, 02:19 AM
Ruger48's Avatar
Default Ground Wire
Put ground wire on 10 days ago no problem since....Sure wish the dealships would read this forum....Ruger48
Old 07-15-2012, 06:22 AM
Novae21's Avatar
The ground wire seamed to fix my no start issue. It think the next thing I will do is upgrade all batt wires starter wire and grounds. Maybe to a #4 like the ones on me golf cart.
Quick Reply: Jeep Won't Start
