Jeep will not start
Jeep will not start
Ok, so last night I went to the store and when I got out put the key into the ignition and it turned part of the way but would not go any further. The jeep has power but will not start. The steering wheel is locked and I have a manual so it is not in park.
I had the kids with me and it was getting late so I have not tried much. Today after work I will try disconnecting the battery and rebooting the computer and try my spare key. Does anyone else have any suggestions? Could it be a fuse? If so, which one?
JK-Forum Founder
unfortunately, you're not alone. here's a thread that might be useful to you:
https://www.jk-forum.com/forums/show...p-Not-Starting
I had some difficulty with my 2007 not starting.
Turned out to be an electrical glitch that caused the security function to go off-keeping the jeep from starting, etc. I searched the JK-forum, and found the official TSB, printed it out, and took it to the dealer-they fixed it-at no cost to me- and no problems since.
However, it took me a while to figure it out-I took out my battery, charged it over night, then it started. Happened again-replaced my battery, thinking it was not keeping the charge-it started, then it happened again-searched the JK-forum and, armed with the TSB report, went to the dealer and it was fixed as above.
It will probably start if you disconnect the battery for a few minutes, then try again-this should be enough for you to get to the dealer and get it looked at.
Hope this helps....
This was my problem. (so far): http://project-jk.com/jeep-jk-tsb-re...e-wcm-skreem-2
Hope this helps....
If you're problem is the ignition not turning all the way, then either you need to wiggle the steering wheel (interference with the steering lock) or your ignition switch has an issue. I think
