Inner door leak?
Inner door leak?
Been fighting this leak at the bottom of door. There's a steady stream of water coming in when it rains and I'll have a little pool of water on the floor when I leave in the morning.
Any ideas???
You can make out the stream in the pic.
Any ideas???
Check your foam around the top and door. Usually some readjustment there will stop my stream. I'm all ears if someone has a better solution. My theory is the water is channeled down the inside of the rubber and thus door then rolls onto the lip there.
......or is yours coming from under that lip upon further review?
I had the same issue but thankfully mine was still under warranty. Took it to the dealer and they either replaced door sills or foam around the door sills, can't remember which. So far so good. It did seem that my leak was worse when parked on a decline. I guess that allowed for more water to run to the front of the doors, then down and around the doors onto the floor. Good luck.
Check your foam around the top and door. Usually some readjustment there will stop my stream. I'm all ears if someone has a better solution. My theory is the water is channeled down the inside of the rubber and thus door then rolls onto the lip there. ......or is yours coming from under that lip upon further review?
