If Your Freedom Top Doesn't Leak, Post here . . .
Old 03-21-2007 | 06:32 PM
  #31
mmaxwell8's Avatar
Default No Leaks Here
I've had my two door JK for a couple of months now and experienced two or three heavy rains...only one leak the first time I had to tops off. After that I followed the sequence in the owners manual and have had no problems. Being in sunny NE Florida I've had the tops off at least a dozen times and still no leaks. For the last couple of weeks I've even gone without the anchor screws in the back and still dry.
Old 03-21-2007 | 06:57 PM
  #32
FRDesign's Avatar
Originally Posted by fraynes1
I don't have the leak from the freedom top panels but rear window leaks and have a wet carpet. Supposed to be a TSB for this though.
Same here.
Old 03-22-2007 | 04:46 AM
  #33
Riprock's Avatar
Never leaked had tops off 5 - 6 times and been through touchless was about 5 so far so good.... I did however have my passenger side panel fill up with water. Enough that I had to hold it at an angle to drain the water...onlyn happened that once, but never any water inside
Old 03-23-2007 | 07:38 PM
  #34
'07JK Fan's Avatar
Default Still no leaks on my Freedom Top.
Still no leaks here after a little rain (for these parts anyway) and 4 cycles through the local, touchless carwash... Wondering what will happen after this summer in the PNW and several removals/reinstalls of my Freedom Top. Hoping that compression set doesn't become a problem. I've only had the front two panels off a few times thus far (4 in total). Nite!
Old 03-24-2007 | 01:30 PM
  #35
Rescue X's Avatar
Never had a leak since 23 Dec...
Old 03-24-2007 | 09:17 PM
  #36
glwood6's Avatar
Rec'd JK 12/14/06, no leaks, just creaks...it's quiet now, sitting in storage while I run the soft top...
glwood
Old 05-07-2007 | 02:21 PM
  #37
2climbbig's Avatar
never had a leak in mine since say one. Have had it since October of 06
Old 05-07-2007 | 02:54 PM
  #38
Originally Posted by Renegade
Mine have never leaked. I have never read the manual about how to take them off... I just start loosening things and twisting things until they come off. I then put them back on in some sort of similar fashion.
My thoughts exactly! Where's the fun in it if you have to read the manual?
Old 05-07-2007 | 07:42 PM
  #39
b1pig's Avatar
mine leaked ONCE the first day I had it. i tightened up the hand-screws and it quit. No trouble otherwise. I've had mine off a few times, but the rear of the top is off.... I have the front panels on as a suedo-bikini for now.
At least until I get some better sunglasses than my cheapo-backups I have now.
Old 05-07-2007 | 10:08 PM
  #40
rupedog's Avatar
My JK came with a soft top so I had them throw in a hardtop or I wouldn't buy it. The said ok, buy I would have to wait 4 weeks. It came in 3 weeks later. The put it on and it has never leaked a drop. Very happy with it.
Quick Reply: If Your Freedom Top Doesn't Leak, Post here . . .
