Idle
Mine's a little rough as well. It's very slight. I'm due for an oil change and I'll have them check it out. Several people on this board have posted that they had vacuum leaks which created the rough idle.
Sometimes I think I've killed it at a red light it is so smooth. Maybe it is because the ride up to the redlight isn't as smooth.
600rpms, unless the A/C is on (rarely)
Interesting the differences people have on their idles. Read the other threads on this also. I took mine in today and they reset the computer on it. The idle was better but not as smooth as some people say. Did the people with vacuum leaks have codes thrown up by the computer? What would be a good way to check myself for small vacuum leaks?
idle
way to check for vacuum leaks is to spray the carb cleaner. if you hear change in idle or smoothness changes you have a leak. don't spray too much as it can drift
Mine has idled rough at times too. Usually when I get off the interstate and sit at the red light for about 10 seconds. It acts like its going to stall for a second then it comes back.
