How to switch off the annoying 'beep'
Old 02-13-2011 | 03:15 AM
Markdsv's Avatar
Cool How to switch off the annoying 'beep'
Guys,
I like to keep my music on in the car when I am working in my garage, however as soon as I open the drivers door a intermitted beep sounds ( any suggestions how to disable the 'beep'? (apart from closing the door )
Am I the only one with this problem?
Cheers,
Mark
Old 02-13-2011 | 04:06 AM
drphil's Avatar
disconnect the door's wiring harness...
Old 02-13-2011 | 04:51 AM
Are you talking about doing this to your jeep or anoter vehicle?
Old 02-13-2011 | 05:44 AM
Markdsv's Avatar
Default indeed my jeep
My jeep and I am a bit reluctant to cut into my doors wiring loom, I assume other items are connected the this as well.
Any thoughts?
Old 02-13-2011 | 05:47 AM
drphil's Avatar
Any thoughts?
you ever take the doors off? it's the same wiring harness...under the dash is a quick-connect plug, just disconnect that, problem solved.
Old 02-25-2011 | 02:01 PM
Markdsv's Avatar
Good point, yes I do.......()
Old 02-25-2011 | 03:19 PM
Zilla's Avatar
There is actually a fuse for that. It's just for that door switch.
Old 02-25-2011 | 03:27 PM
TURTLECON's Avatar
If the ignition is set at ACC, the beeps should go off after a few moments.
Old 02-25-2011 | 03:28 PM
fett 4 real's Avatar
or buy a radio for your garage
Old 03-04-2011 | 03:37 PM
armyretiree's Avatar
Default No More Dinging
When your driver door is open use your finger or other object and close the latch on the door, it will click closed twice no more ding...just remember to pull the door handle before closing the door or THUD the door won't close and you will be startled lol
Quick Reply: How to switch off the annoying 'beep'
