How do you KEEP the JK running FOREVER?
#31
Haven't had much feedback on where people's failed engine were made.
It takes some effort to find and read the number; probably beyond their "it's too much effort" threshold.
#35
Thanks, I'll keep at it
#36
Stick a mirror in there, and with a flashlight, you should be able to see the numbers. It helps to be able to read backwards.
#37
Go in from the top, leaning over the driver's side fender. Reach in, behind the head, with a rag that has some type of wet cleaner on it. Wipe the area where the head meets the block, on the back of the engine. The number is just below the head/block parting line. Scrub it well, to get the dirt and grease off the flat surface.
#38
Hey ronjenx,
OK, so I was able to find the last 8 digits of my VIN, it's just south of the frost plug, just as you said.
I have looked and looked for another stap with a S or a T and I be dam to find it. In relation to your VIN, were is your "T" stamped?
Thanks I will look in the AM, the seekos are eating me alive!
#39
Hey ronjenx,
#40
Well, I'm dissapointed. I have taken another look today, and all I can see is the 8 VIN digits all in a row. Nothing infront, after, bellow or to either side. Looked as far as I physicaly could. No motor code, just last 8 VIN digits. I've cleaned the back many times, nothing....but man can I get to the VIN number quickly now!!
Any chance it would be stamped else were? Would a 'build sheet' tell me if I could request one.
Maybe mine came from Costco.
Dam, really want to find out.
Thanks
Thanks
