How do you.........
How do you.........
how do you remove the plastic shifter piece that connects to your Shifter head?
Ok so i broke this thing about half way down the shifter.
it is the plastic bar that is inside the shifter.
How do i replace this piece?
Does anyone have a online service manual so i can take it apart?
Sorry, Yes it is an Auto. i tried to take a picture but the camera wont take a pic in the metal tube. the metal tube that is around the shifter neck. the plastic bar is in the metal tube and the shifter knob connects to it.
From what I have seen so far it is a normal Auto shifter and you are talking about the rod that connects the button to the safety mechanism. This will require you to remove the shiter assembly to replace most likely. Everything I have found shows crappy pictures and it goes in from the bottom. I have had one person tell me to pass on some are not connected in the bottom and you can screw a screw into it or superglue something to it and pull it out the top.
hi i think i have the same probleme that you have , hade to call the towing tonight because the shifter was stuck in park .
here s a link i found it s for a 2004 wrangler but it s the same thing .
most people fix it with a chop stick ..
pictures starts a #8 post .
i hope it will help you cheers
pm sent !!
pm sent !!
