Hood Screws
@Rednroll - do you have this issue as well since you're up there in Michigan?
Most likely scenario is that the previous owner removed them and the paint came off the screws from the tools during removal/re-install. I have no corrosion on mine. When I got my cowel ding from door removal, I read a write-up where someone had removed that center vent to provide better access to the back side of the cowel. I looked at that write-up and didn't see where you gained much additional access and realized I would need to remove painted screws in the process which was something I rather avoid. I purchased a glue stick dent puller instead. So I'm going to speculate previous owner had a similar problem and removed those screws and damaged the paint on the screws in the process. Which obviously wouldn't be covered by warranty and is the likely the reason not a lot of us have seen these screws rusted before. Likely self induced paint chipping off from removing those screws. Would make sense as well if the plastic washers are missing.
After you have them pulled out, use a mild rubbing compound to get that white oxidation off, then follow that with a polisher, and then wax to bring back the shine. These foam pads work really well from Harbor freight to get things like that off the paint when combined with a polisher.
https://www.harborfreight.com/6-in-p...pad-60309.html
I've never seen this and had the same thoughts as you in that they were some type of replacement screws. Maybe poor factory paint if they're not replacements.
