Hood Alignment
My JK has had a misaligned hood since I purchased it five years ago. It likely had body work done by the previous owner. It is perfectly aligned on the passenger side but site too low on the driver side. It this adjustable by moving the body-side hinge? If so, would I need to loosen the passenger side as well as the driver or just the driver side? Thanks
This procedure is about installing a Hi-Lift hood mount kit, but it includes the procedure for adjusting the height of the hood.
https://www.jk-forum.com/forums/jk-w...d-mount-41906/
This procedure is about installing a Hi-Lift hood mount kit, but it includes the procedure for adjusting the height of the hood. https://www.jk-forum.com/forums/jk-w...d-mount-41906/
I don't see why you couldn't just adjust the one side. If you read through the procedure, you'll see that I used rags to hold the hood up a bit while doing the install (which you won't be, of course) and making the adjustment. Regardless, it's very quick and I'll be surprised if you don't return and say done, easy-peasey, thanks. LOL.
