HELP,no fresh air?
HELP,no fresh air?
hello everyone!just got a new jku and im having an issue with not getting air to come in thru the vents when its set to the non-recirc mode.is this just how its made?in my other car,if i crack open my windows air blows strong thru my vent without turning the system on.i would like to get some air into the cabin without opening the windows or turning the system on even if im not using a/c ,thanks for any help!other than this,I lovemy jku,wish I got one sooner!
My 2009 is the same way.
Other cars I've owned would let air flow in with out the fan on.
I'm thinking it's due to the aerodynamics of a brick or maybe the recirc door closes when the fan is off.
Thanks for the replies,I like to have the top and does of but have hour air push thru the vents to balance the temp, I'm weirdo,I know.Lol.hope the seals are just new...
my cousin just told me his fresh air comes in strong in his 2012 rubi. i think ill bring mine in to get checked.My jku is a 2014 so its still under warranty,might as well use it...keep the replies coming!!!
I have a 2012 and it doesn't let fresh air in unless I turn on the fan at all. I had the HVAC control module replaced @ 8,000 miles due to it constantly cycling between fresh and recirculate. I've also wondered if no fresh sure was normal with out the fan so I checked with others at the stealership and they were all the same way. I believe this is normal..
Jeeps are not cars and operate in harsh environments like crossing streams or being in sandstorms in the desert. While fresh air vents in cars draw in air to exchange cabin air with no fans, jeeps crossing water or in white outs would be wise to close intake vents or design to not draw in if not needed.
