Help with my Tie Rod...seems to sit low.
I just replaced mine because the TREs were shot. I went with SteerSmarts Yeti but as noted above, several good choices available. I'm sure you'll find a match for your needs.
I'm not sure either. My wife has been driving it to handle the kids sports activities. We took it on a quick trip to pismo and drove on the beach a bit but noting too crazy or anything that required much effort. I haven't been driving the JK for a while now since I have been taking public transportation because my job pays for it. I did notice that the diff cover is scraped on the bottom as well, but as you mentioned it should have bent upwards. I drove it around this morning, and did not notice anything weird with the steering. I guess its time for an upgrade!
Let me know if you guys have any suggestions on what to replace it with.
Thanks again!
Thanks again!
What kind of off road use does your jeep see? I'm all for upgrading components, but a good tie rod isn't cheap. If the jeep is never off road or only sees a few dirt trails, it might just make more sense to find another factory TR that someone pulled off. I hate saying replace shot OEM things with more OEM things, but not everyone needs a $350 - $600 tie rod. On the other hand, if you do wheel that jeep, it is probably a good excuse to bite the bullet and upgrade it.
I'm in the same boat as the previous poster....still scratching my head how it got bent in that direction.
I'm calling the wife snagged it backing up over something. As others have said I have a synergy and am happy with it. I too was bummed when I had to replace mine. It was an unplanned upgrade and for reason it hurt a little to drop $375 on such an unsexy upgrade.
I'm running the Synergy as well. The real kick to the nads isn't as much the $375, as it is the additional $60 or so for the steering stabilizer clamp.
My Synergy seized after two years as those pichbolt seams allow too much road grime and salt inside the adjuster sleeve. It ended up being 325$ down the tube.
I'm so glad we don't have to worry about salt here in north Texas .
You mentioned in your original post that you have the Mopar 2in lift. Who did the install of the lift? Like mentioned, that bar should be bent the other way, so I'm trying to figure out how it could have been bent in that direction. The only thing, I could think of is that if you had the lift installed at a shop, then somehow that tie rod or steering stabilizer got hung up on something as they were raising the hoist.
I really appreciate everyone's feedback on this. I am still fighting with myself on whether or not to buy the Steer Smarts Tie Rod or go with another factory one. I plan on keeping my JK forever so upgrading it little by little is why I am leaning towards the Steer Smarts over OEM.
