Help, this light cam on, on the way to work
Cool thank you for quick response, was just making sure wasn't some really bad......
I can take care of that whne i leave work, thank you again.
~Jeremiah
~Jeremiah
I believe that the TPMS is set at 37lbs, and there is a tolerance of 7lbs +/-. For those that experience the "mood" of the Jeep, that could be because you are just at the limit, and the temperature affects the reading. Some dealers will change the TPMS settings for you, and some will not due to "liability issues".
