HELP!! Jeep not starting - not starter or battery
Driving the jeep home from work yesterday in the rain, made a turn hit a splash puddle and the engine died and wouldn't re-fire.
Things I have checked
Codes from OBD port - no codes found
Codes through Jeep diagnostics - message on dash - DONE
still turns over strong
acting like its out of gas, have a half tank and added more just to be safe
will be checking spark shortly - easy enough to do.
not sure how to check for fuel pump
Since no codes removed the negative battery cable.
no water, pulled plugs, checked throttle body, intake and all the goodies.. nothing..
Still not throwing any codes
checked fuses and they are good
