Help identifying squeak in driver's rear wheel area
I've tried various fixes for this and none have worked. I've also tried searching for a similar issue in other threads and have come up blank.
I've got a squeak coming from the area of my driver's side rear wheel. When driving, it is fairly constant. A high pitched squeak that sounds a little like rubbing styrofoam together. Or like a mouse being gently tortured.
I cannot duplicate it when the Jeep is stationary by pressing on the bumper or anything.
I cannot find it by crawling underneath and trying to move various suspension parts with my hands.
If I apply lateral pressure to my tire with my hand, I can hear a faint squeak. This might be the same thing but it's hard to tell. The other three wheels do not make this sound.
It appears to be something in the wheel/brake/spring area. I've taken the wheel off and can also make it squeak by pressing on the brake rotor.
But I cannot find out where the damn thing is coming from!! Any help would be much appreciated.
Tex,
I know this sounds strange....but next time the squeek happens lean forward on your seat. I had the same noise and it turned out to be the ratchet mechanism for raising the drivers seat.
Dave
Dave
I had the same thing,Dealer checked it out and they found nothing.
I just got a OME lift with shocks trac bars,figured no more squeak.
But it is still there.Less noticible though
I have the same squeak on the driver's side rear. It sounded to me like the top was a little loose and rubbing on the tub, but that's not it. Like the OP, I also can't make it happen when it's sitting still. Subscribing to this thread to see what other's find.
Guess I should search before starting another thread. O well. I have the same issue but on the passenger rear side very very very very annoying lil almost like a mouse squeak! But it gets worse when the brakes are alloyed. Someone please help us!!!!!!!!
BTW I have 3.5" skyjacker lift
