Help with diagnosis
Help with diagnosis
When driving at low Rpms and lugging I am feeling a pretty bad vibration. It is only when I under a load like if I were to take off from 2nd gear and accelerate or if I don't down shift when climbing. The vibration comes about 2000 rpm and is gone by about 3000rpm. I I take of with a high acceleration the vibration isn't there. Or if I am at freeway speeds there is no vibration. I checked my drive lines, motor mounts everything. Anyone have any idea what it could be? I have a 2 door 2007 with a 6 speed lifted, on 35s
Thanks
Thanks
Are you sure you don't have 3.21s or 3.73s. I think you are getting the small shake and the feeling your going to stall because you do not have enough low end torque to spin those big tires. i have noticed on steep hills when coming to a complete stop. i need to ride the clutch more or i will stall in first gear with my foot to the floor. I have the 32inch tall tires, 3.21 gears and the 6speed in my 08.
