Help with Dent in Bumper !
Bumper
Yea did that myself to. I drilled a hole in the back to get access to area, heated it up with a heat gun and push it out with a rubber hammer and the handle off a (clean) toilet plunger, used this cause end is rounded.
Take it off and you can push it out from the back. I did the same thing and then I sprayed it with bed liner. It covered the white stress marks and looks almost as good as new.
Take the cover off. Use a blow dryer to heat up the plastic and push it out. it won't be perfect but it will be better.
re
I had similar "dimple." Replaced the bumper. The second time... got a steel bumper... I recommend just getting the offroad bumper. You see used ones all the time on the forum.
