Help! Blown Engine!
Since it seems like you didn't pull the dipstick once in 3000 miles how can you say they didn't fill your oil? Oil change places don't hire the most competent people, so if I do use them I make sure to check it after.
I'm surprised the oil light never came in, but it happens that way sometimes.
Maybe I'm paranoid, or am just used to it because I'm a truck driver and have a habit of checking my fluids regularly. Bottom line, it's your responsibility, but I'd still press Havoline to get some compensation. Good Luck.
Also i think a compression test would show bad rings / bad ring to wall seal.
If you are burning 6 Qts of oil you have to have a bad cylinder or several have sloppy clearances.
My compression test last summer showed 175psi-180psi all around for reference. I have an 09 that had 90,000 when I tested it.
im very mindful of the oil in all my vehicles & even my lawn mower, im a GM mechanic so I see things like this on a regular basis. it sucks for the customer since most don't know anything other then to put gas in the vehicle and go. but ultimately its up to the owner to keep the vehicles in good running condition, I tell customers all the time to check their oil every time they fill up and some do and some don't. most that don't always end up coming back and spending money out of their own pockets.
My father in law had a similar experience with Walmart oil change. He was only able to make it 200 miles before throwing a rod. 3000 miles seems like a stretch for riding with no oil. Anyways he fought long and hard to get them to cover it even though the technician admitted to forgetting to fill the engine with oil. Good luck with yours. I suggest you keep pursuing this bc they tried to bully him to accept partial reimbursement.
I think timeline is going to be key here.
Date the ghost oil was put in AND the date you discovered a bent rod.
First question is did the pan have the plug in it? This would lock down that the oil was poured right through it.
I would present your case to Havoline and ask for a new engine and installation labor. They will likely send you off to contact "headquarters".
I would then write a letter detailing the reason for the requested new motor and installation labor.
When it come to this sort of thing, details are key. If they can't wiggle out of the liability it is cheaper to buy you a motor than go to court or arbitration.
I went to Havoline, and they said "Some engines can go through 6 qts of oil just burnin' it up. That noise will go away once the new oil works down into the lifters and rockers. It's completely safe to drive. I understand the scare, but it's nothing to worry about..."
I've filed a comprehensive claim through Geico against Havoline's Insurance Company. An adjuster is meeting with my mechanic to confirm his diagnosis. Engines can burn oil, but there would be a ton of evidence on the spark-plugs, and tail-pipe if my Jeep had burned 6 QTS in such a short time. I may end up eating a $500.00 deductible, but that sure beats paying 10x that for a new engine. Insane!
Everyone on this and other forums who ran their engines dry of oil has also stated they don't check the oil level on a regular basis, if at all between oil changes. Some have even said they shouldn't have to.
To those readers who don't check the dip stick once in a while, there is something to be learned here. Just do it!
February 20th was when the "Oil Change" was supposedly done. May 12th was when the rod was discovered. I have the paper-trail from Havoline showing that they have been the only ones who have done my oil changes, and there has been no previous indication during any prior service. The screw was in, and while that does confirm that eventually it was put on, I don't know that some numb-nuts didn't just put it back on for a reason known only to him.
the place you use sounds like they change oil and that's it. someone making $8.00hr doesn't care and isn't properly trained to look for things like what I explained, they probably don't even check the oil level before changing it. its gonna be tough to prove the Havoline was at fault since you drove 3k miles before the problem ever occurred, I hope it works out for you but chances are you are going to have to shell out $500 and Geico will end up loosing the fight against the Havoline insurance. you will make out good but Geico is going to get the shaft lol
I had a similar situation and my dealership where a guy brought in his CTS for an oil change and drove to NY, well when he got to NC (6.5hrs away) the engine locked up. during his oil change we found the car was 1qrt low, we told him and he said ok and would look into it when he got back from NY. when the engine locked up we provided him a rental to finish his trip and we sent our tow truck to pick up the car from the Cadillac dealership so we could inspect the car ourselves. upon inspection we found that the intake tube was full of oil because of a bad PCV, no leaks or anything else was found. we ate the rental bill, the tow bill and even offered him a 25% discount on the engine and because im the shop foreman and get paid salary we werent going to charge him any labor, and he took as we were trying to "cover" up something. he ended up going to court and losing since he was notified about the oil being low and didn't want to diagnose the problem.
I agree there will be evidence of an engine using 6 quarts in 3 miles. Inspect spark plugs, compression test all cylinders, exhaust for residue. Loss of oil is either leaks or is burned.
