Help!!! Battery light issue
Old 06-17-2010, 08:27 AM
Lorrel's Avatar
Originally Posted by jonboy
14 volts isn't too much. its suppose to put out 14.4 volts
Yea, I agree.
A static battery should put out about 12.6-12.9 V. With the engine running, the voltage at the battery terminals should read between 13.6 to 14.5 volts.
BTY, to the OP.
Glad you found and fixed your problem.
Old 06-18-2010, 11:43 AM
wolfpuppies3's Avatar
Default Page 200 of your manual
2. Charging System Light
This light shows the status of the electrical charging
system. The light should come on when the
ignition switch is first turned ON, and remain on briefly
as a bulb check. If the light stays on or comes on while
driving, turn off some of the vehicle’s non-essential
electrical devices or increase engine speed (if at idle). If
the charging system light remains on, it means that the
vehicle is experiencing a problem with the charging
system. Obtain SERVICE IMMEDIATELY. See an authorized
dealer.
Quick Reply: Help!!! Battery light issue
