Help with Alignment
Help with Alignment
I need some good suggestions please. I’d really appreciate any help. I’m out of ideas.
I’m trying to adjust the toe-in on my JK. It’s toed in a bit - 3/8”.
Problem is when I try to turn the knurled adjuster, it won’t turn. Not even a little bit. My last attempt ended up stripping a bit of the knurling and it still didn’t budge.
Everywhere I’ve looked makes it seem like turning the adjuster is easy. Even doable by hand. I’ve sprayed it with PB Blaster, and tried a lot of different things, but now that it’s stripping, I’m coming here for help.
Any suggestions? Anyone ever have this issue? Thanks for any solutions.
Edit: Forgot to say, it is a JKU Sahara with 33” tires, and everything else is still stock.
Really appreciate the help.
Crazy thing is there is not much rust. It looks fine, just a little “patina” which is why I’m surprised it’s so stuck.
I guess I’ll pull it off, see what’s going on, and if I can’t get it to turn, I’ll buy a new one. Thanks again.
Jay2013jk (09-09-2023)
