Help with #3 misfire P0303
Ok glad to know it's the same on other peoples vehicle.
I did buy the coil pack already but I figured might as well replace it since I plan on driving the JK to 200k with the lifetime powertrain warranty.
Do others have experience with bad coil packs or is this definitely a waste of $$ and I should go return it.
Normal gap is 0.050".
One thing to keep in mind if a coil pack is suspected of being the cause of a misfire...
Each coil in the pack fires two plugs. If the coil was the cause of a #3 misfire, for example, #6 would also be misfiring.
Thanks Ron. I will definitely remember that one. Good piece of information.
