Heater Air Temperature
My Jeep is a 2013 Two Door MOAB with the Climate Control set-up.
EDIT: 80K on it.
Lately is seems to NOT be blowing very warm air when first started.
The Temp gauge is up on the line where it always is when warmed up.
Later in the day when it is warmer outside it seems to be blowing a little warmer air. Still not hot.
Any insight on this issue?
Bob R
EDIT: 80K on it.
Bob R
There is no water valve for the heater core. Water flows through it all the time the engine is running.
Your problem could be a stuck blend door, a bad blend door actuator, clogged core, or low coolant level. Could also be a bad HVAC control panel.
First thing I would do is see if the blend door actuator moves when you select different temperature setting. There are quite a few threads here that will show where to look.
Check both heater hoses at the fire wall to see if both are hot.
Jay2013jk (02-23-2020)
I had mentioned to my wife a few times that the heater was not blowing very warm air. She keeps telling me that it is working just fine.
This last Tuesday I had an eye exam where they put some stuff in my eyes that messed up my vision for a while. I let the wife drive me home. Guess what I discovered? The heater is working just fine on the passenger side.
With air blowing hard from all dash ducts, and the temperature being much lower on the drivers side. From my reading this is a classic heater core starting to plug with casting sand issue.
I believe I have isolated the problem. This late in the Winter I can probably put off the heater core change out until late Summer.
Bob R
Bob R
Bob R
Bob R
