Headlights
#21
A place called Susquehanna motor sports will sell you a complete plug and play kit including:
Hella H4 lights and bulbs
Heavy gauge wiring harness (completely plug and play)
Relays
I've had mine for the better part of a year and love it. It is a night and day improvement. It's also an easy install.
Relays
Do u have any pics u can post of what the lights look like when on ?
TIA
#23
Anyway, the light output from my headlights was obviously greater than that from Interceptor's blue bulbs. Mine had a distinctive yellow tint while his appeared quite white (looking from behind the lamp at what it's illuminating, not at the lamp directly). But, regardless of what you may hear about blue bulb making it easier to see at night, I completely disagree. They absolutely do not. Those $60-80 bulbs are NOT worth the money you're paying for them.
Stock housings: On the way back I did the same thing with Jiz Nim, except he has stock bulbs and housings. There is no comparison. The beam pattern from the stock housings sucks bad, and replacing the bulbs, even with an $80 bulb, will NOT fix that.
Bottom line: The most cost effective answer is the IPF lamp assemblies with white bulbs. I did not have a set of the white bulbs that Northridge now offers, so can't comment on that. But, when it comes time to replace your bulbs, get the cheapest Sylvania bulbs and I think you'll be quite pleased.
BTW: Here's a picture after the sun came up Sunday morning (just thought I'd throw this in 'cuz it's such a pretty sight) ...
Photo by Ryen.
#25
#26
I've been running the Daniel Stern setup for almost a year now. That is the Cibie E-code lenses with the upgraded and relayed Susquehanna H-4 conversion harness. I am using the GE Nighthawk Platinum bulbs, which are far and away better than the silverstars. I have found this setup great and completely trouble free. Lighting output is much better than stock and the e-codes light up the signage at the side of the road very nicely. I also have four KC 8" HID's that bring the daylight, but for times when I can't run them the Daniel Stern setup works like a charm.
#27
Installed IPF with blue bulb last night, much better than stock and the pattern is vastly improved. IPF on photo left (passenger side) and stock on photo right (drivers side).
#28
The e-codes and other halogen conversions are a great improvement over stock.. but when it boils down to it, HID plus a quality projector is the way to go.
https://www.jk-forum.com/forums/members/spore-23653-albums-projector-retrofit-4815/
I still owe pics of the beam pattern, but I can tell you right now, this retrofit made the hella e-codes look like stock in comparison.
#29
