Has anyone actually managed to get 2.38 quarts of fluid into the rear diff?
I just did my second diff fluid change and once again I could only get about 1.9 quarts of fluid into the diff before it started to ooze out very quickly. I know the 'to-spec' amount is 2.38. Just wondering if anyone has actually been able to put that much in without jacking the rear end up?
How long did it take to flow into the axles? I waited about 30 minutes then went back out, backed the jeep up onto 3/4 foot ramps and was only able to put in a little bit more.
That would be more than enough time. I was just thinking it may be possible to fill it too fast.
No, no, no!! Filling to the center line of the axles is inviting a major spooge release through the vent tube! Fill just enough so the oil will enter the axle tubes - no more. If you have a stock diff cover, that would be right where the fill plug is.
