Grill guard! Which one to pick?!
#21
a part for everything.....
I searched around a bit more and found info. There are a few relocation kits now available; Or-fab, Teraflex, and EVO. Google even provided a how-to video.
I'm ordering the Or-Fab bracket from Quadratrac and putting on grill guard
#23
It's not difficult. However, you do need the tools. I used a sawzall with a metal cutting blade to remove the bracket. You can use a cutoff wheel, but I used the sawzall because the blade will flex some and you can get it right down in there. To mount the MBRP light bar, two of the indentations on the plastic filler panel must be cut out. I tried doing this with a razor knife, but that plastic is pretty hard. (I know, that's what she said). I wound up going to Harbor Freight and buying I cheap dremel tool. By all means, get the dremel tool. It will be money well spent. Y'all correct me if I am wrong, but a lot of after market bumpers and light bars must use these same holes that are located behind the bracket. So.......that bracket will have to be removed some time. Go for it!!!!
#24
Originally Posted by RedOffRoad
Here is mine with the Aries Grille Guard
