Greased Steering Cloumn - Still Have Knock in Gas Pedal...
Mine does the exact same thing as well, it has 7500 miles now. I have noticed the clunk periodically, gradually getting worse. Sometime it does it, sometimes not. I just figured out today that it has something to do with heat. It seems to me that it is the steering shaft expansion slip joint, where the splines are. I think that the outer part of the slip joint absorbs the heat and expands. The outer tube actually protects the inner tube from the heat, thus it doesn't expand as much. This in turn causes a sloppy fit in the splined joint.
Can anyone concur?
Can anyone concur?
Can anyone concur?
Can anyone concur?
idea if I'm understand right...
just a shot on the dark, but if the two portions of the splined shaft are lengthened a bit more (such as lift would do a little bit?) would that lessen the contact area on the inside for the two pieces to knock together, or maybe decrease the 'angle' at which the inner shaft can move when there is a lot of heat on it? Totally just an idea, so please let me know if I'm wrong and talk'n out my a$$...
Your "search for noises" is understandable. Your JK is still new, under warranty, and your perfect baby. The sooner you give in to the noises/rattles and the dark side, much improved you will be.
well said berjepalon, but don't worry with almost 20k on it I've come to terms that it is never going to be showroom quality ever again
well.. at least for 100% pristine stock level anyway
took mine to the dealer this morning. they said it needed both intermediate steering linkages. said it was a "common problem" and that the parts weren't shown to be back ordered, so should have them next week.
I will update if this was actually the fix.
Can anyone concur?
Can anyone concur?
It's just one of those annoying things that I'll get around to when I've finally had enough. Kind of like drilling the side mirrors to let the water out. I'm just happy it has "the knock" and not "the clap."
I don't see grease being able to fix it. for very long anyway. have you felt that shaft after 30 minutes of driving?!? It will turn to oil and just run out. I was very close to wrapping the steering shaft in header insulation, but the thing only has 7600 miles, let the dealer tech screw with it. I have better things to do.
