Gearing I Got this back from jeep
so i emailed them just out of curiosity and i want to know what i should do and what yall think
The front axle is Next Gen. Dana 30 Solid Front Axle and the rear axle
is Next Gen. Dana 44 HD Rear Axle and the axle ratio is 3.21
Furthermore the ratio for each gear is as follows:
FIRST 4.46
SECOND 2.61
THIRD 1.72
FOURTH 1.24
FIFTH 1.00
SIXTH 0.84
REVERSE 4.06
my setup is a 4in lift with 33x12.50s and its a 6 spd as you can see i go through mud soft sand and i climb every now and then so help me out please?
FIRST 4.46
SECOND 2.61
THIRD 1.72
FOURTH 1.24
FIFTH 1.00
SIXTH 0.84
REVERSE 4.06
Nothing
33's with a manual, live with it. Regear if you go to 35's or taller.
Unless you have $1500 laying around and nothing whatsoever better to spend it on. Then look at the chart here and decide.
https://www.jk-forum.com/forums/show...76&postcount=4
I found the 3.21 intolerable even with 30's. The cost is high so I understand the previous post, but my Jeep is a different beast with lower gears.
If you had the 4.10 or even the 3.73 it might be acceptable but the 3.21 is awful.
