Gas pump issues...
#21
Dammit Jake, you jinxed me! It just happened to me again today.
I relocated my evap cannister, so I don't think it's taken a hit, but maybe I need to climb under and take a look.
#22
#23
Location: Hangin in the sunshine state....staging forum..
ok this is taken from the service manual, talking about the ESIM switch(the white plastic part on the canister)
"the fresh air lines and hoses from the ESIM must have clear openings to the atmosphere. Check the fresh air lines, including fresh air filter, for obstructions or restrictions at the ESIM Also check the routing to the exit to atmosphere. If a restriction is present, the system will not allow free flow passage of clean air, and an EARLY SHUT OFF of the fule fill nozzle may occur during fuel fill"
edit: The fresh air filter line runs from the ESIM up to a filter just below the gas fill hose, you can see it if you remove the driver side tail light.
#24
Fixed
well mine is all better, I replaced the ESIM and I was able to fill up with the nozzle on full blast and it never cut off till full
my ESIM where the hose attaches was hanging on by a thread, when I went to remove it it came right off. and the black hose going to the other side of canister wasnt kinked as bad as I thought but I still replaced it.
check for leaks/breaks guys
#26
Here in Australia this is a common problem with the diesels (apparantly you don't have the CRD engine in the 'States?). The issue seems to be a sticking venting valve in the tank and requires repair by the dealer.
Not sure why it only affects the diesels here though; maybe the oily fuel builds up on the valve (which is suceptable due to it's design) and jams it, or maybe the diesels have a completely different tank and venting system to the 3.8L petrol models?
#27
Sponsoring Vendor
Off Road Evolution Rep
Tkob is that little hose in your pic inside the canister or was that connected to the ESIM ( white doohickie )?
#28
I've filled up about 5 times now and no shutting off
edit: maybe your esim switch is bad? its only 10bucks maybe worth trying and the filter is 7 and change
#29
I have had similar problems at several different stations. I would put the nozzle all the way in and when the level got full, it wouldn't shut off right away. I would lose about a quart of gas....a fortune just dropped to the ground.
