The future demise of Jeep and it's Wrangler
#31
CEO says the next version needs 2 improvements: dramatic weight loss and improved drivetrain. He is stressing weight reduction. The new Ford F150 small bed lost 500 lbs. by going aluminum. So if the next Wrangler goes aluminum and keeps body on frame, that's only 500lbs. That new Wrangler is still too heavy at 3,500 lbs.- it has to get to 3,000 lbs.
#32
....or, as voters we could elect public servants to reverse one size fits all legislation. Iam tired of carbon credit get rich schemers running the narrative, telling us how to live and living a different way.
#33
Saves close to 2/3rds unsprung weight in contrast to solid axel, and keeps ground clearance on rebound. Hopefully Jeep designs this with 33's as the stock size wheel on a 3/4 scale JK frame.
Facing reality: Smaller, lighter, IFS or full independent suspension is the future of Wrangler. Upgrading will be more expensive, and one still has the option of solid axels, it will just cost. But since many are already replacing stock Dana 44's with aftermarket axels it's a wash. This change is going to happen no matter who owns Jeep. I will miss solid axels, but admit I am not the majority of the Jeep demographic. I would say the majority on this forum is not the overall average buyer.
http://www.allpar.com/SUVs/lil-blue.html
#34
#35
Fact still remains that ifs/irs is still heavier than a solid axle with more moving parts to fail. Unsprung weight doesn't matter to gas mileage but rather total weight. With the ifs they will lower it and put a large facia to cover said parts and the aerodynamics will increase mileage.
#36
Re read article, these are jeep engineers doing their job. The TJ axle went from 300 lbs. to less than 120lbs. Unsprung weight matters for handling & mileage. Cutting weight happens everywhere; a few ounces here, a few pounds there. Increase power to weight ratio along with aero and efficient trans / power train are the goals for any platform. Jeep must design for the abuse we will give it.
#37
"It (IFS) did increase unsprung mass about 25 percent vs. a shorter travel independent front suspension, although it still had lower unsprung mass than a beam axle design ( solid axel)" from the article. This IFS version of suspension shaved off close to 200 lbs. when compared to solid axel. Switch to aluminum body and scale down to 3/4 size of JK and 3,000 lbs is in reach. I know this is going to eventually happen. I hope Jeep keeps 12" travel and at least 33" wheels in smaller than JK frame or 35" wheel in same sized JK frame.
Customizing our rigs will cost more. Still possible, but more difficult.
#38
And the goal to get better gas milage would be a lot easier to accomplish of we would go back to burning REAL gas. The 10% corn oil SUCKS and is killing our MPG. All a government ploy,force a worse product to use and then laws to improve MPG. The wranglers most of us know will soon only be available by building one which is what most of the guys on here have done anyway we'll either have to find an older on to use as our starting point or pay for the new version and go from there...
#39
The future ideal goal is to get rid of gas. Not short term our use short sighted thinking, but our grand kids and after thinking. Shale oil from Canada isn't for the USA, it's going to Europe and China. Even if we went to war with all oil nations to take oil, including China, it is still a limited supply. Want to eliminate the terrorist threat? Pull out of the oil Middle East.
Diesel & diesel / electrics for long range are the long term future power trains. Fuel that is not petroleum based but waste based/ plant based is renewable and has less ill affects on environment and nation conflict. Electric motors with a few hundred pounds of torque at zero rpm and a range of 300 miles isn't a bad thing. Want to go further? Add more diesel to charge the batts.
I once liked hydrogen fuel but the oil companies want to base it on petroleum, so there's no difference.
#40
