Fuse for 3rd brake light?
Thanks for the answer, I just knew it would be you with the info, I have perfect vision(when wearing my contacts) and I still can't make out every little bit of printed data on that fuse cover
Is there a PDF somewhere with an easier to read version?
Matthew
Sent from my iPad using JK-Forum
Not thrilled with the product so far, the way it fits, or in this case, doesn't fit the empty hole in the wheel is kind of lame
Maybe it depends on your tire carrier but my Ace tire carrier didn't go along with the sparse instructions
Did you get yours installed and working ok?
I had to goto the hardware store anyway and I found some rubber washers a little bit bigger than a quarter, with varying size holes
So I got two with the smallest size hole and I think one of those on the backside of the rim might make a damn fine friction device to keep these lights in place better, at least in my instance...
Matthew
Mine do not fit in there as good as I would like. I figured for $40 @4wheelparts I would get something rather decent but at this point you can achieve the same thing I did for $10 on some basic 3/4" red LEDs off eBay.i am using the stock Sahara 18"as my spare. They fit but only by having tension on the wires from behind. Not to mention I had to trim the connectors so they would go through the back of the lug holes in the rim.more trouble than its worth. Look good but hate it cost $40
First off, yes it was M1 just as pictured, now my center high mounted stop light is working just fine!
Hmm sounds almost like a European description
So you just have a spare fuse box hanging around so you can put in the one fuse in question so you can go above and beyond helping someone?
I gotta meet you sometime and buy you a beer or maybe a steak!
Do you goto the Jamboree in Bethel? Or do you ever make it to All Wheels? Or anyplace south of Lewiston?
Your always the one to count on for great solid and dead on electrical advice...
Thanks again
Matthew
Thanks again
Matthew
Thanks again
Matthew
Thanks again
Matthew
It's the one I used in this thread:
https://www.jk-forum.com/forums/stoc...-study-174919/
I don't get to southern Maine much any more. The woods and mountains in the western and northern parts of the state keep me pretty busy, along with the railroad in Ellsworth.
chmsl stop working help!!!
OK I Was installing my 3rd brake light back on to my swing out tire carrier and now the light don't work I have checked fuse M1 and it seems good my jeep is only 5 days old why is it not working
