Funny feature...
Funny feature...
Since my truck is currently waiting some bullet-proofing parts I've been daily driving my wife's Unlimited. I'm not sure how I did it or if I did anything, but it all of a sudden started unlocking all 5 doors when I open either front door after shutting the truck off. What'd I do? It's a nice feature but it'd be nice to know how to turn it on/off in case she doesn't want it to do that all the time.
Does it have the driver information system, the one with the menus? There is a personal settings item where you can set that.
Or you can do it the old fashioned way:
Automatic Unlock Doors On Exit Programming
The “Automatic Unlock Doors On Exit” feature can be
enabled or disabled as follows:
1. Close all doors and place the key in the ignition.
2. Cycle the ignition switch between LOCK and ON/
RUN and then back to LOCK four times ending up in the
LOCK position.
3. Press the power door unlock switch to unlock the
doors.
4. A single chime will indicate the completion of the
programming.
5. Repeat these steps if you want to return this feature to
its previous setting.
NOTE: Use the “Automatic Unlock Doors On Exit”
feature in accordance with local laws.
LOCK position.
doors.
programming.
Ah, that's how I did it!
I cycle the key on during refuel to keep the fuel slosh issue in check. That way I can see when it's getting close to full and reduce the nozzle rate.
It doesn't have the menu stuff. Thanks for the reply, it'll be nice to know how to turn it off if we want!
