fuel light on
fuel light on
Hi everyone, I have a problem with the fuel pump. Even though there is half a tank of diesel fuel, all it takes is a bend or braking to give me the yellow diesel reserve warning light. Then after a while the needle goes up but not precisely... Where can I go to solve this? Because this situation is quite boring. It's on reserve and I don't know how many km it will do. Sorry for the writing errors. Thank you
If I'm understanding you correctly, you are having a problem with intermittent fuel level sensing. I would start with the fuel sending unit in the tank. Sounds to me like it might be gummed up, or getting stuck as the fuel moves around in the tank.
AntonioJK11 (09-13-2023)
yes, exactly, a curve or braking is enough for the level to be low. Could you explain better where to put your hands? Thank you
