Fuel leak gas tank
Fuel leak gas tank
Since September I’ve notice gas smell from jeep. Worse when it was full, went away at about half tank. No visible leak. About a week ago I parked on a different spot. Tank was half full. Smell got really bad. I got down on the ground and saw gas just dripping off the skid plate. Took to mechanic and after dropping the tank he found sending unit cracked. $600 later I have a new sending unit. Jeep is 2010 unlimited with 35,000 miles. Anybody have the same problem. Changed brakes for the first time at 35,000 miles also.
Yep. The white plastic on the top of that unit gets fine cracks in it, allowing fumes to come out making the Jeep smell like it is about to explode. If you too off your tank often, fuel can deep out of those cracks.. My tank has a ton of mud and dirt saturated with gas fumes... I dropped the tank and changed that unit myself.
