Freedom top leaking
Really though, you should laugh about this. Do you happen to have a pic of the first installation? Because in my mind I am picturing the freedom panels on, then the rear - there had to be a pretty good gap and tell me you weren't able to bolt the rear back down?!
The simple way to tell which order to put the panels on is look at the inside seam of each panel. One goes over the other to create the flat seal. You put the one where you can see the rubber "gasket" on first. I think the key thing to do is make sure you have the panel all the way forward and straight before you crimp it down.
I'm not sure if it's the same, but on my '07 freedom tops there is a plastic flip down. I'm pretty sure when you have the Top (back part) off, you flip those little plastic gap thingys down to fill in the gap/void that the Top (back part) would fill.
I've had those panels on and off more than I can remember, never a leak.
I see what you guys are saying and yeah it is kind of funny however the panels were on correctly after all. I would have noticed a big gap like that. Im dumb not that dumb (at least I think). So that wasnt the issue and my top is still leaking. Oh well must be a defective seal or something
There is a leak path through the adhesive on the FPs in the areas you describe. Take a look at the corners and make sure the adhesive is squeezed out all along the edges at the corners. If not, you could try to seal them yourself or else take in for warranty.
you had this one comin' back at ya
When puting on the freedom panels, be sure to set them straight down from above and NOT slide them in from the side. This us whats rolls the lip of your weather strip causing it not to seal correctly.
