"foam Kit" from TSB on leaky tops
Old 10-10-2008 | 07:35 PM
  #31
ronzep's Avatar
Originally Posted by smundara@yahoo.com
Mine had a minor leak over the door handle on one side. I installed a few pieces of black marine and automotive weather strip (1/4" from Home depot) where the foam was compressed and it appears to be water resistant now. I tested it during the rain today both parked and while moving.
The first time I noticed this I adjusted the door surrounds and adjusted the soft top but the foam gets compressed over time and the leak appears again.
I decided to do it myself to avoid any damages from the dealer. It is still under warranty but I prefer to do it myself!
I hope this is useful. Just follow the original foam outline and add a piece where you see the foam being compressed.
The roll is about $2.60 MD brand
Agreed. Home Depot has a plethera of weather strippin that will fix these water leaks. I have been complaining about the sheer wind noise from the top where it connects, and found some weather stripping that has worked good so far for the past few days, and no water leaks!
Old 10-29-2008 | 05:35 PM
  #32
The Scrodd's Avatar
Default leaking tops
I hear you mine has 3500 on it and worked on mine for an hour think I got it took it to the car wash sparyed the top all over and so far no leaks.... This is a hard top I am talking about
Old 10-29-2008 | 05:51 PM
  #33
Ryanc's Avatar
can you all that fixed your tops with the weather stripping show some pics
Old 11-03-2008 | 05:19 AM
  #34
smalls's Avatar
+1. Pics please!
I have scheduled service tomorrow morning for my soft top and my rear locker.
Luckily its supposed to rain tomorrow and wednesday so I can see if it helps right away.
Old 11-13-2008 | 05:09 AM
  #35
smalls's Avatar
I had the TSB performed on my JK last week at the dealership. I washed my car after wheeling this weekend and NO leaks.
One of the ways I know its working is that now I see for the first time, the wrath of the waterfall when opening the door. I guess that water used to just pour inside my jeep. Now it stays high until I open the door.
I am much happier now though.
Free from the tarp at last!
Old 11-13-2008 | 05:51 AM
  #36
RedneckJeep's Avatar
All this is bullshit. They'd be puttin a new top on my damn Jeep.
Old 11-13-2008 | 06:17 AM
  #37
CdnJeepDan's Avatar
Mine's in for this, the door pillar rattle, and a shorting blower motor today.
Man, I hate having my Jeep in the shop. :(
Old 11-13-2008 | 07:52 AM
  #38
saltman's Avatar
Typically, it is not the top that is the problem. It is usually the header seal. Water seeps in the gap in the front and then follows a path to the weak door seal/header intersection. Sometimes it get's in between the top and the seal and does the same thing. The root of the problem is the header seal and the top being in plane with it as opposed to being on top like all previous Jeeps and most convertibles. It's the kind of problem that is a design error or weakness depending on your perspective. The dealers are stuck dealing with a difficult/impossible thing to fix.
Quick Reply: "foam Kit" from TSB on leaky tops
