"foam Kit" from TSB on leaky tops
Old 10-01-2008 | 08:15 PM
Hellbound13's Avatar
Originally Posted by bigbluejk
I am talking about my soft top, but the file covers both. here is what it looks like in mine after 30 minutes or more of rain if you are curious:
seats and floor equally wet.
Thats a lot. That sucks. Mine leaks but not that bad. Although Id rather have that leak than the ten other issues Ive had.
Old 10-01-2008 | 08:17 PM
bigbluejk's Avatar
Oh that isn't the only issue... It is just the only one I could easily photograph and the only one some pieces of magic foam might fix.
Old 10-01-2008 | 08:18 PM
I feel ya. Maybe they have some magic foam for my transmission and steering shaft.
Old 10-01-2008 | 08:25 PM
bigbluejk's Avatar
They replaced my intermediate shaft once which seemed to help for about 92 seconds.
Old 10-01-2008 | 08:28 PM
Ha, well I will one up you. I HAD TO REPLACE MY STEERING SHAFT, because the dealer told me its NORMAL! Now 5000 miles later the clunk is back and I have ordered ANOTHER shaft. I guess I will just do this every 5K. You would think the aftermarket would step up on this, but I have emailed several companies to no avail.
Old 10-01-2008 | 08:32 PM
bigbluejk's Avatar
I try to hit potholes in rythem so that the clunk goes with my music.
Old 10-01-2008 | 08:56 PM
So are you just hearing your clunk or feeling to? Mine is not audible, mostly felt. It feels like a knocking in the steering wheel when going over bumps. Especially when holding the lower right part of the wheel and turning it slightly.
Old 10-03-2008 | 05:29 AM
Originally Posted by MB-08-JK(R)
Yep, that soft-top leak is pretty common. First time in my dealer told me that the top was not put up properly but since their leak expert had worked on it everything was going to be OK. It rained that night and through the next day. Any guesses? Yep, it leaked like a bitch. So Wednesday I picked it up after they had installed the exact seal kit AND a new windshield header seal. Unfortunately it isn't supposed to rain for the next 5 days! I'll keep you posted. Oh, by the way, I highly recommend the new header seal. It appears distinctly different at the ends of the header where the leak occurrs. The rubber is wider under the corner of the door and the channeling out of the header is different.
Good Luck.
Any pics of the new header?
Old 10-05-2008 | 12:18 PM
bigbluejk's Avatar
Thank you for the Photos. Do you have the new Metal header I have read about? Is there anyway you could take a photo of the seals with the top pulled back a bit? Thanks man.
Old 10-05-2008 | 12:28 PM
Raiderse's Avatar
Not sure but have an upgrade kit at dealer for install due to leak at right front. drips on ride end of dash under windshield header riser. Manu July 08
Quick Reply: "foam Kit" from TSB on leaky tops
