First Off Road Trip - 4WD Low Problems
Hi All,
Just got my 2012 JK Unlimited. Automatic.
I was out on a trail in 4WD Low, when out of no where no power is getting to the wheels. I put it in 4WD High and have the same problem. Then put it in 2H and the Jeep works fine.
I then tried to put it in 4WD Low and again the same problem. Then put it in 4WD High and I WAS getting power, weird.
After I got back to my house I did a bit of troubleshooting and get these results:
-2H works fine
-I can successfully put it in 4WD High
-4WD Low does not transfer any power to the wheels and the engine just revs.
Any thoughts on this problem?
thanks
-2H works fine
thanks
Is there any harm in getting into 4Lo on the pavement to see if I can get this working?
Originally Posted by JamesP
Never occurred to me. The shifter is getting all the way to the bottom though and that does not explain why it would disengage into N in the middle of the trail after being in 4LO for about an hour.
I wonder if ur shifter cable is shredding and stretching and not allowing u to fully pull the tcase all the way back into 4lo?..... A linkage issue perhaps. Or u just need to man up and pull harder....pull on that damn lever like ur trying to start a push mower.....
Worst case take it to dealer and complain till thier ears bleed and they will resolve it.
A Second Look
Over the past 15 years, I have assisted several new Jeep owners learn how to get into and out of 4WD. The most common mistake I witness, with folks who have auto is this.
- From 2WD to 4WD Hi, and return - no problem
- From 4WD Hi to 4WD Low - one problem. Here's the recommended procedure:
-- JK moving 2/3 mph forward
-- Shift tranny to N
-- (In one motion) Shift the TCase to N and then pull back to the 4Low position pulling
slightly to
the left. This should place the TCase in 4Low and the 4WD light should be lit on
the dash.
-- Shift the tranny back into DRIVE ! This is the step that most new drivers
overlook. They rev the engine, red line the tach and curse the very name of Jeep for
having the nerve to not work as advertised. But it is. Shift the tranny back into Drive
and I think it will work just fine.
Good Luck.
slightly to
the dash.
Good Luck.
