Finally for my Squeeky JK friends
Old 11-07-2007, 08:46 AM
motabus's Avatar
Default Finally for my Squeeky JK friends
NUMBER: 06-004-07
GROUP: Clutch
DATE: October 26, 2007
SUBJECT:
Squeak-Like Sound Due To Manual Transmission Clutch Disc
OVERVIEW:
This bulletin involves the replacement of the manual transmission clutch disc.
MODELS:
2007 - 2008 (JK) Wrangler
NOTE: This bulletin applies to Wrangler vehicles equipped with a 3.8L engine and manual transmission (sales codes EGT and DEH respectively), built on or before February 28, 2008 (MDH 0228XX).
SYMPTOM/CONDITION:
The customer may experience a squeak-like sound from the transmission clutch. This sound will occur when there is a change in engine torque. The squeak-like sound can be heard most often during: clutch engagement, acceleration (tip-in), and/or deceleration
maneuvers. This condition may be due to the clutch disc internal components.
Old 11-07-2007, 08:57 AM
mikejwil's Avatar
"...built on or before February 28, 2008..."
So they're planning to continue installing defective parts until 2/28/08?!?!? I just ordered one and had hoped that the squeak would have been fixed by then...
Old 11-07-2007, 09:41 AM
motabus's Avatar
LOL i just noticed it said 08, thats funny.. figures they would still make them bad knowing its an issue
Old 11-07-2007, 10:06 AM
RepressedSince15's Avatar
OK - There's the admission of guilt, where's the part about the fix? That gym shoe isn't getting any quieter...
Old 11-07-2007, 12:59 PM
motabus's Avatar
you can check out the full tsb in the TSB section but to sum it up they are putting in a new clutch plate. I just got back from dropping mine off, I will let you know how it all goes
Old 11-07-2007, 06:44 PM
JasperK's Avatar
Default Mine was replaced 3500 miles ago...
and haven't had any more issues. Squeek started for me at 1000 miles, got tired of hearing it at 3000 miles. Dealership replaced the clutch assembly. Now at 6500 miles and no squeek to date, runs great. If it's done right, should take care of the problem.
Old 11-08-2007, 04:21 AM
Question about the squeek:
Is it just a noise, or is there a mechanical defect that may cause problems down the road. I can barely hear it sometimes, and it doesn't bother me. I don't want the dealer to tear into it if it's just a little noise.
Old 11-08-2007, 04:43 AM
Bodo's Avatar
I called my dealership to get an appointment for the G40 recall and while on the phone I also mentioned the squeak and the associated TSB for this and they acted as if they were totally unaware of the problem and the TSB. How is this possible? Are some service departments just so out of it or are they playing dumb? If this squeak isnt going to cause any damage I too would just as soon they don't mess with it.
Old 11-08-2007, 04:46 AM
Black Ruby's Avatar
Yahoo!! Finally that chirp was starting to drive me crazy. I was very reluctant to let the stealership rip into it to try and find the problem. I sure hope this it the permanent fix.
Old 11-08-2007, 04:53 AM
JackMac4's Avatar
THANK GOD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have just about had it with the squeek on my clutch. I was just planning on calling my dealer finally after listening to it for months.
Quick Reply: Finally for my Squeeky JK friends
